I've had a DMX-741U for a month or so now and have had some problems with Ku feeds that I think "might" be related to the funky LO numbers on the Ku setup. Almost every time I scan Ku I get TP numbers well up into the 12500 range with SRs of 20000 which NEVER produce any video or audio. Cband side of this LNBF seems to work very will but Ku is another story.
So since I'd been toying with the idea of using one of these on my current 10ft Winegard dish, I ordered a "Standard" version last night that will use the standard LO of 10750 for Ku scans. I'll swap that U version out on my SAMI first and see if the funky TPs go away then try one of the two on my Big dish after that. It's a pretty easy swap as they will fit in the Chaparral scaler ring and there is a setting in my 4DTV receiver to use them for whatever analog signals that "might" be available. Of course I do have both a Pansat 3500 and an AZBox Elite slaved to that 4DTV receiver too. Be good to see some A/B test results between the Norsat C/Ku LNBs and that DMX on that Winegard dish.
Yup, more toyz to play with!
Because I can!
Heh, as if the drag racing I do wasn't already expensive enough???
