>Remember that you are slaving the 4DTV to the GEOSATpro master and unless the GEOSATpro is powered OFF, the 4DTV cannot select the
>polarity. If the GEOSATpro (master) is powered ON, then the 4DTV (slave) only can receive channels that are on the polarity selected
>by the GEOSATpro (master) receiver.
Ok, so from now on, when I want to have W5, I need to power off the geo. Simple enough, not a big problem
>"SNG" channel names are actual channel names provided by the uplinker.
Yes, I know, a sports network I believe.
[*]What Satellite are you on when you scan these channels?
[*]Is there programming on these channels?
[*]What is the programming if it is available?
Yes, the ones which are live have various sports events on them.
I'll make a list of what I've scanned later on and post it.
>If you provide specific examples of a band, satellite and a channel that you scanned in including the service name, scanned frequency and
>poarity we might be able to tell you what satellite and LO, polarity settings are correct or incorrect.
Yes, I meant to do that already but haven't had the chance. Or, I could always post my geosat file generated using the tool? Would that be ok?
>Did you install the Dielectric Slab into the feedhorn? If so, remove it
Nope, nothing but the LNBF.
