60 mm, so the PLL-SL1 is actually a bit smaller than the Amiko, almost exactly the same size. Lone Gunman's C/Ku LNBF must be a little different than mine. Thanks, Ke4est.
I don't think he means those connectors, but the one sticking up vertically on the C section. In this picture you can see how close it is to the Ku LNB:
Yup, those are the ones I'm talking about. They are on the C section of that DMX741 and it's two of them sticking out of there on mine because it has the 22Hz switch built in. In fact yours looks like it's off center just a bit for the same reason.
Hey Michael, do you know what the diameter of the end of that Ti one is without the plastic piece on it?
And did you have to break the plastic off the rear part or will it come off in a way that it can be put back on?
Not off hand, but if I get around time later I will take one apart and see.Hey Michael, do you know what the diameter of the end of that Ti one is without the plastic piece on it?
I cropped this picture in Photoshop....I tried to hide most of it.I have way more junk on my workbench, but you are a close second!
I decided to try a little of the C/Ku LNBF building myself today. I used a pair of PLL LNBFs. Might as well make it good right? Not real complicated I hope. Just saw off the Ku scalar. Cut a hole in the back of the C-Band LNBF. Line it up and glue in place, I hemmed the skirt and put the dress back on the Ku LNBF too.
View attachment 109454 View attachment 109455 View attachment 109456 View attachment 109457 View attachment 109458 View attachment 109459
Ditto.... Keep us updated.But how about the F/D for that Ku part, or is that important? That is essentially the same thing that Robby did with the NS741.
I'm real interested in seeing how this works.
A few unknowns for me in this little project as well. I may get a chance to test it Sunday. I need to round up my meter I have loaned out. Tomorrow is the game!![]()
I'm not sure what the rod is for either. It's location suggests to me it is for cross polarity isolation. But that is a guessDo you know what that rod inside the C1WPLL is for? I'd debated knocking it out and filling in the two holes on either side, but I didn't know if it's there just to support the throat of the LNBF to keep it from becoming deformed from over tightening or such, or if there's some other reason for it being there. None of my other LNBFs have any like that in them.
I'm not sure what the rod is for either. It's location suggests to me it is for cross polarity isolation. But that is a guess![]()
