At my work we have had a 10 receiver headend up and going for the past year. We use Dish Network 311 receivers. However at random times some receivers would freeze, lose signal, etc. I would have to reset them. They are all on a rackmount UPS so it is not power.
We purchased a larger dish from Toner Cable to try and correct this problem. They sent a legacy DirecTV LNBF. The new dish is over a meter in size.
I can get a signal (118 strength) from 119 on an older 7000 series receiver but our 311 receivers cannot see the new dish at all.
Our system also uses 3 DP34's to connect all the receivers.
Do I need a Dish Network LNBF (ie DishPro LNBF) for our new dish for it to work with the 311 receivers?
It is or was my intent to use the 110 LNBF (DishPro dual) on the old Dish 500 to provide our input from satellite at 110. And just leave the 119 disconnected. Connect the 110 from the Dish 500 and the 119 from the large dish and connect them through the DP34's.
What do I need to do or get to be able to use the larger dish with the Dish 311 receivers and DP34 switches? We want both 110 and 119 satellites.
