DishOnline won't stay online (VIP622 Broadband problem)
I finally got around to plugging my 622 into my router to check out Dish Online.
I'm using a cable modem (Comcast) and a Linksys WRV200 router with latest firmware ( 1.0.39).
The VIP622 gets an IP address, I can get a list of stuff from the Dish Online menu sometimes, but then after a few minutes I get message about needing a broad band connection and I can't get the lists anymore.
Broadband Setup shows the IP address previously acquired (which I can still ping from my PC) but the status shows "Not Connected". If I do the Reset Connection option, sometimes it will go back on line and work again for a bit, but then the same thing happens. Regardless of whether the 622 says Connected-online or Not Connected, I can ping the address (unless I unplug the cable - then the address is dead so I know it's not an IP addr conflict)
If I do get a list and try download something, it just says something like processing request and doesn't really seem to do anything.
Router is showing a valid DHCP lease for the VIP622 and I can ping it, but I guess it seems to be having trouble communicating. Other PC connected to the router is fine, and I have tested the cable (I'm a computer tech by trade).
I've rebooted the router and the 622, no change.
Tried a different port on the router, no change.
NIC on the 622 has a solid green light, and blinking orange light.
Anything quirky on the 622 I need to be aware of, or any special settings I need to have (or not have) on the router? I do have QOS enabled for Vonage (separate VLAN), but before I start messing with random stuff figured I'd check here and see if anyone has any ideas....
Any idea what's going on? (Edit - VIP622 is running version L613)
