DishNetwork Uplink Activity Report - 4/2/2008 3:10pm - 631 changes
That is my understanding too.
FWIW the Austin HD Local channels are not listed as even being up-linked on 61.5 anymore due to the 'duplicate channel number bug' in TSReader. But my new wing dish for 61.5 picks them up just fine :)
Talon Dancer
Your understanding is correct. The Austin HDs were not in the report last week, but info in the thread last week listed them as uplinked and available.
http://www.satelliteguys.us/1288823-post166.html
Here is the HD locals so far this week.
ADD 5150 WDAY MPEG4 HD Tp 1 Spot 11 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6
ADD 5150 KSWO MPEG4 HD Tp 3 Spot 13 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 7
ADD 5150 WKOW MPEG4 HD Tp 5 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 27
ADD 5150 WOLO MPEG4 HD Tp 5 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 25
ADD 5150 WAPT MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 16
ADD 5151 KXJB MPEG4 HD Tp 1 Spot 11 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 4
ADD 5151 KAUZ MPEG4 HD Tp 3 Spot 13 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6
ADD 5151 WISC MPEG4 HD Tp 5 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3
ADD 5151 WLTX MPEG4 HD Tp 5 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 19
ADD 5151 WJTV MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 12
ADD 5152 KVLY MPEG4 HD Tp 1 Spot 11 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 11
ADD 5152 KFDX MPEG4 HD Tp 3 Spot 13 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3
ADD 5152 WMTV MPEG4 HD Tp 5 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 15
ADD 5152 WIS MPEG4 HD Tp 5 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 10
ADD 5152 WLBT MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 3
ADD 5153 KVRR MPEG4 HD Tp 1 Spot 11 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 15
ADD 5153 KJTL MPEG4 HD Tp 3 Spot 13 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 18
ADD 5153 WMSN MPEG4 HD Tp 5 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 47
ADD 5153 WACH MPEG4 HD Tp 5 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 57
ADD 5153 WDBD MPEG4 HD Tp 1 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 40
ADD 5160 KXII MPEG4 HD Tp 1 Spot 13 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 12
ADD 5161 KTEN MPEG4 HD Tp 1 Spot 13 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 10
CHNG 5162 WEYI MPEG4 HD Tp 3 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE
TO 5162 WEYI MPEG4 HD Tp 3 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE MAP 25
ADD 5162 KXIID MPEG4 HD Tp 1 Spot 13 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 20
ADD 5170 WLNE MPEG4 HD Tp 11 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6
ADD 5170 WPDE MPEG4 HD Tp 13 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 15
ADD 5171 WPRI MPEG4 HD Tp 11 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 12
ADD 5171 WBTW MPEG4 HD Tp 13 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 13
ADD 5172 WJAR MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 26
ADD 5172 WFXB MPEG4 HD Tp 13 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 43
ADD 5173 WNAC MPEG4 HD Tp 13 Spot 16 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 54
ADD 5173 WWMB MPEG4 HD Tp 13 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 21
ADD 5190 WBND MPEG4 HD Tp 5 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 57
ADD 5190 WXLV MPEG4 HD Tp 9 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 45
ADD 5191 WSBT MPEG4 HD Tp 5 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 22
ADD 5191 WFMY MPEG4 HD Tp 9 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 2
ADD 5192 WNDU MPEG4 HD Tp 13 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 16
ADD 5192 WXII MPEG4 HD Tp 9 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 12
ADD 5193 WSJV MPEG4 HD Tp 13 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 28
ADD 5193 WGHP MPEG4 HD Tp 9 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 8
ADD 5200 WISN MPEG4 HD Tp 9 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 12
ADD 5201 WDJT MPEG4 HD Tp 9 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 58
ADD 5202 WTMJ MPEG4 HD Tp 9 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 4
ADD 5203 WITI MPEG4 HD Tp 9 Spot 14 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6
ADD 6340 WKRN MPEG4 HD Tp 13 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 2
ADD 6341 WTVF MPEG4 HD Tp 13 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 5
ADD 6342 WSMV MPEG4 HD Tp 13 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 4
ADD 6343 WZTV MPEG4 HD Tp 13 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 17
ADD 6347 KSTP MPEG4 HD Tp 3 Spot 11 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 5
ADD 6348 WCCO MPEG4 HD Tp 3 Spot 11 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 4
ADD 6349 KARE MPEG4 HD Tp 3 Spot 11 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 11
ADD 6350 KMSP MPEG4 HD Tp 3 Spot 11 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 29
ADD 6365 WSB MPEG4 HD Tp 15 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 2
ADD 6366 WGCL MPEG4 HD Tp 15 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 46
ADD 6367 WXIA MPEG4 HD Tp 15 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 11
ADD 6368 WAGA MPEG4 HD Tp 15 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 5
ADD 6369 WPCH MPEG4 HD Tp 15 Spot 17 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 17
ADD 6495 WJSU MPEG4 HD Tp 9 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 40
ADD 6496 WIAT MPEG4 HD Tp 9 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 42
ADD 6497 WVTM MPEG4 HD Tp 9 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 13
ADD 6498 WBRC MPEG4 HD Tp 9 Spot 19 Rainbow 1 61.5w UNAVAIL HIDE HD MAP 6
How are they keeping the receivers from getting confused with the same channel numbers being used in different spots? How does the receiver match the guide data?
It must be some new system they have to save on channel numbers. Eventually adding another 1000 channels would rack up the numbers.
Most likely a new smart card.
Nah. the Transport ID is different. The package code may be different as well.
Thanks for the corrected lists you post.
Do you do these corrected lists manually? If so, do you use the Transport ID to figure out which channels are really available? or do you use some other method?
TIA - Talon Dancer
I fully expected..
"MUTT & JEFF" (the gruesome twosome, etc.) to flip the switch on SciFi this morning. Simply friggi'n amazing!
The death spiral continues a Dish Network:mad:. Time to look at alternatives.
Gerry
TIA - Talon Dancer
Most of it is automated now. Maybe all, he says with crossed fingers. :D
Transport ID is part of the "picture" in determining the where. Package codes are what actually says "available".
Thanks for the updated list JohnH. I turned in a request to Rod about TSReader's NIT/SDT parsing bug but I haven't heard anything back yet.
They are definitely doing something weird as I was scanning around in DVBDream last night and noticed it too was picking up the wrong names.
Hello all!! New member here, first post, but have been lurking for awhile. :rolleyes:Anyways, have a contact at Dish that has always been reliable but even he does not know any exact dates for new national HD (he has been able to tell me before). All he said was 24 new national HD within 6 weeks, which is not really anything new or hasn't been said before, but I thought I would chime in, say hello, and if he comes up with anything more substantial, I'll let you know. I'm sure, though, that Scott's sources are just as knowledgeable.
Sorry for the rather useless post, but as a new member, I guess you gotta start somewhere.....;)
From one Cub fan to another...I'm hoping hell freezes over soon... :)
Despite global climate change, I think the chances of Hell Freezing over are considerably better than seeing BSG in HD on Dish tonight. I cannot find a Las Vegas line on those events, however.
Welcome bforce, and it sounds like your source is saying new national HD will be comming SOON
Wow we never heard that before
Just joking
Welcome to SatGuys. Any and all info is welcome. Thanks for letting us know what you've heard.
Not useless at all; IMHO you started with quite a bang! 24, eh? :eek: Did he say which ones? I wonder if he's including RSNs in that count?
D
DishNetwork Uplink Activity Report - 2/23/2008 5:30am - 27 changes
D
DishNetwork Uplink Activity Report - 4/9/2008 1:11pm - 1 change
