Dish Single lnb hook up
jomusic
if i am hooking single receiver to single lnb do i need switch in between the connection ?
or do i just take cable hook it to lnb to the receiver ?
Thanks for the help
A switch is needed for 2 or more LNBs or when connecting more than 2 receivers to 1 LNB. Just run the RG6 through a ground block then on to the receiver.
Fyi
I tried that way and receiver did not recognize the lnb. found why
if you legacy lnb than it needs a switch.
hooked up legacy lnb to switch and to the receiver works fine.
What are you trying to do?
If you have a single LNB (or dual),. No switch is needed for one slot (119 only, 61.5 only)
If you have 2 duals for 110 & 119, then a switch is needed
Twins have switch built in : )
Boosting the 121
Current 129 uplink list.
