Dish Pro Plus LNB Availability
Ok now that there is hardware available...let me ask this question. If a person took a DPP Twin LNB, the DPP44 switch, would you be allowed to feed the following sats (110/119) to these respective recievers?
921 (with sepatator for both tuners) + 522 (With separator for both tuners) + 311 + 510?
Thanks!
Alt
921 (with splitter for both tuners) + 522 (With splitter for both tuners) + 311 + 510?
Thanks!
Alt
When connected to a DPP44, the DPP Twin functions as a DP Twin. So yes, it would work, but more expensive than necessary. I assume you mean separator for the 921 and 522.
Yes I meant separator (corrected)...More expensive yes, but if it means being able to use one cable going to my living room it is worth it.
Alt
I think what Pepper was getting at, is you don't need the DPP twin LNB when using the DPP44 switch. You should just need a regular DishPro twin LNB. The DPP44 allows the use of separators, even with the non-DishPro Plus LNB.
Slightly confusing the DPP and DP! If the DP LNB will work, it will save about $50 on the installation :)
So the DPP44 and DP-Twin LNB will allow the hookup of 921, 510 and 311 receivers?
Thanks for the information and the potential savings of $$!
Alt
