I have been away from satellites for years and now want to get back into it.
I just bought a Dish. It's the 500+ series and had an older dish 322 receiver. It says software version L 248.
I have one lnbf pro for 110 with single output. I have a dual lnbf pro plus for 119 and 118.7 that has 2 outputs. They are 2d and 1f, and a dual lnbf pro with 2 outputs for 129.
I followed the hookup to a dpp44 with and without a separator.
With the separator connected the check switch comes back with non bandstacked quad on ports 1,2,3,and 4 is not support as a diseqc device. Also non Dish pro lnb on dpp 44 ports 2 and 3.
On the satellite 2 on the 322 it says dp feed 119 even on port 1 and 110 even odd on 2 and no connection on 3 and 4.
I took the separator off and used dpp44 and 2 outputs to 322 and got non band on 1 and 4 and non dish pro on 3. This was satellite 1. Satellite 2 said non band on 1 and 4. It said non dish pro on dpp44 port 0.
Then port 1 and 4 no connection, port 2 single 110 odd, and port 3 dp dual 129 odd.
Does anyone have any ideas?
