Quick question for 21.0 remote owners, can you control TV2 with IR (instead of UHF) signals with these remotes? Or is control of TV2 only available with UHF signals like it is the old remotes (like the one with my 722)?
Sorry, TV2 IS only UHF.
Ed
Can anyone confirm that this applies to the 222k as well?Sorry, TV2 IS only UHF.
You can program the unused color buttons to control the audio from your DVD player while in TV mode. Either that or you can press the DVD button and it should control the audio that way. If it doesn't, just teach the remote to use the volume buttons from your DVD player while you are in DVD mode.
1 . Thanks, but the volume buttons seem to 'fixed' on controlling TV volume while in DVD mode. I tried teaching the 21.0 but it didn't take.
2. It seems that the AUX mode is apparently the only one that can be toggled to control the volume of something other than the TV. I was able to toggle the 21.0 to control the DVD volume while in AUX mode...but the problem is that even in SAT mode, the volume buttons control the AUX (DVD) volume!!!
Any help on this would be appreciated. Has anyone been able to use the volume buttons to control anything other than the TV's volume?
"In AUX Mode Volume Override, the volume control defaults to the AUX mode instead of TV mode. In this mode, you cannot access TV volume at all. This is if you wish to use the TV as a monitor and control all volume through the stereo system."
TO PUT IN AUX MODE VOLUME OVERRIDE:
1.Press and hold the AUX mode button until all buttons light up.
2.Press #.
3.Press Volume +
4.Press 0.
5.Press #.
TO PUT BACK IN TV DEFAULT MODE:
1.Press and hold the TV mode button until all buttons light up.
2.Press #.
3.Press Volume +.
4.Press 0.
5.Press #.
This SHOULD work for virtually all Dish remotes such as the 6.0, 6.2, 6.3, 8.0 as well as the 21.0.:up
Yer welcome!
Ed
BTW, I haven't tried this myself. Got it off Dish tech portal. Good luck!
From the 222k Receiver Manual:
Changing UHF/IR Using the Switch
Your TV2 remote control has a switch to change from sending both IR and UHF signals to sending only IR. The switch comes preset to the UHF position, which sends both types of signals, but if you have a clear line of sight to the satellite receiver you're controlling with this remote (for example, TV2 is in the same room with TV1), then you can change the setting to the IR position to lessen the likelihood of another UHF Pro remote control interfering with yours. This applies to TV2 in Dual User mode. To use TV2's remoteinstead for TV1 in Single User mode, flip the blue 2 key to the side with the green 1.
1 Remove the battery cover from the back of the TV2 remote control.
2 Use a small screw driver or a paper clip to carefully change the switch setting.
3 Put the battery cover back on the remote control.
4 Use the SYSTEM INFO button on the front panel to open the System Information screen.
5 Press RECORD on the remote control.
6 Make sure the System Information screen shows the correct information:
• Switch position UHF—IR/UHF Pro
• Switch position IR—IR only.
Hope this answers your question.
I was wondering if the range on this new remote is better?
