Dish Model 625 Receiver
gboyd50
My new receiver can't find the satellites. I have a DP Superdish for 119,110, and 105. I have a Dish 500 with DP LNB for 61.5. They are connected via a DP44 switch with two cables returning to the house to two separate rooms. Currently I am operating with 2 DP301-13 receivers. I tried to upgrade to the 625 first by using the separated included in the receiver package and then going direct with a cable into Sat 1 only. I both cases the receiver can't find any satellites. Can anyone offer a suggestion?
if it's a brand new 625, you might need to run two lines directly from your 119 LNBF to the receiver so it can upgrade software, then put everything back to normal and run check switch.
Dishpro 1000 & DP34
Dish Set Up
