Paid the $299 to get a 622 and have already had it installed. Current bill shows $199 for DP44 (which also received a $199 credit) and most importantly a $99.95 charge for Dish 500. I called and they wouldn't remove the Dish 500 charge. Reading the forum, not sure if should push the issue since I didn't have to pay for the DP44.
What the installer did was setup a Dish 1000 and left my Dish 500. He installed a DB44.
Connected to the DP44 were 2 cables from the Dish 1000 . One for the new 622 and one for the 721 that sit next to each other. Each cable had a splitter put on it at the receiver end so that each tuner had an input. This was done for both the 622 and the 721.
Also he connected a cable from the Dish 1000 to the DP44 for a 510 that is sitting in the master bedroom - I wanted this since the TV in the bedroom is HD and I wanted it ready to go for when I add a HD receiver.
I have 2 other rooms with a receiver and those were left on the existing switch (I checked system info on a 510 and it says device is SW21).
I am in San Jose, CA 95124 and don't know what I really needed. I had wondered about removing the Dish 500 but unsure about the inputs and outputs for the DB44 would allow all my 5 receivers (7 tuners) . I'm also getting another 622 to replace a 510 so that would make 5 receivers and 8 tuners. Total 4 HD tuners and the other 4 on SD.
P.S. One tuner is phantom, the wires outside are connected to the room, but the receiver has moved between 2 rooms and I will also want to add a new SD tuner in the future to one of those rooms so the above paragraph is worded taking this all into account.
