I have an existing dish with hopper and a joey with the solo node. I also have a 211k receiver from they tailgaiter. I want to add the 211k to the dish at home. How would I go about doing so?
But, how do you hook it up with the Hopper wiring. It is already activated on the account.
You most likely would need another sat dish just for the 211k. IF all you have is the hopper and some joeys ,then you could use the third run from the sat dish and run it to the 211k. Works that way with the super joey and a hopper and joeys. I have two runs to the hopper and the third run to my super joey. I have separate western arc dish ,that I picked up that someone was throwing away, and use it just for the 211k . I have it run for my ota terk 44 clip on antenna that diplexes the signal for ota and sat for all my ota antenna needs. IF I ever wanted to reactivate the 211k , I'm all set.But, how do you hook it up with the Hopper wiring. It is already activated on the account.
You would need to add a DPP33 or DPP44 switch to your system. Two lines would feed the solo node and a third would go to the 211.
Ok, I just had dish installed. I have 1 hopper, 1 super joey, and 3 joeys. I also have a 211z activated for my camper. The previous thread stated just run the 3rd line from the lnb to the 211z separately. Trouble is all 3 lines from the lnb are being used on my current set up? What do I do?
Like this:I have an existing dish with hopper and a joey with the solo node. I also have a 211k receiver from they tailgaiter. I want to add the 211k to the dish at home. How would I go about doing so?
The DPP33 doesn't work with a DPP Twin (Dish 1000) nor the Dish 1000.2.You would need to add a DPP33 or DPP44 switch to your system.
