That's the problem. Who's defining which games are "important"??I agree. Fulltime RSNs are unnecessary so long as the important games are broadcast which they seem to be.
That's CONUS only on 129. On 61.5 the highest beam number used is 17, 129 picks up the rest of the west coast beams that 61.5 doesn't need to use.
Digi, this question doesn't pertain to this comment but I'm just curious. I have a 1000.2 (110, 119, 129) with a wing dish for 77w for local HD in Arkansas. It is my understanding that 77 ea is the same as 129 (or which ever) in the western arc so I'm curious why or how the wing dish doesn't conflict with the same channesl on the wa or how does the 722k know which one to pull off of. I assume that my account is either one or the other but how does it then get the hd locals off of 77? Just a rookie question but I have been with E for over 12 years and do my own installations. Thanks, cwk
I'm still curious how these channels are going to look packing all that into one transponder. Not mention how are they going to look on 77 since 77 doesn't run 8PSK, their transponders are 30 megabit instead of 40.
Thanks for the quick response sir. So, are you saying that I could install a 1000.4 and go EA and eliminate the wing dish and the my two vip 722 would just adapt to the signal change and pull the channels that it did before the change? I guess I just didn't understand why the 77w wing dish didn't try to pull in extra channels when I installed and did the check switch. Eitherway, I'm ok and evrything is up and running and has been for a while. I just come up with the questions and get curious when a certain topic comes up in the forum. Thanks again for your response. cwk
The dishes and LNBs are stupid. They just sit pointed at one satellite location and send the same signal down the wire all day long, 24/7. In the case of DishPro LNBs, there is a 1-to-1 correspondence between satellite location and the attached cable. There is one cable per satellite. The DishPro LNB sends both polarizations down that one wire simultaneously, continuously, and forever until it either loses power, or the dish falls over.I guess I just didn't understand why the 77w wing dish didn't try to pull in extra channels when I installed and did the check switch.
Could they be starting the rumored "mixed" transponders, with a few HD and SD on the same TP?
I'm sure they will at least spread the 14 out, perhaps putting some on the existing HD TPs. Maybe they will get rid of some HD PPV now that they have multiple HD on demand options.
Not rumored.... that's already here and has been. Look at EA. MPEG4 SD and HD on the same transponder.
Or there is a rather unique one... MPEG4 HD and MPEG2 SD on the same transponder. SatelliteGuys.US - Subscription 129°W
So far just on spotbeams, CONUS locals on 77, and at 148. CONUS national programming is still separate. Even on the EA, look at 72.7. 3TPs of national HD, the rest MPEG4 SD and Audio.
I agree. I am sure everybody's favorite team is "important". Go Twins![]()
Yep, Thats the main issue why Im not with dish today! Still love the company, but if they cant fill my needs then I obviously have gone elsewhere. Its like sex.. If you cant get that lovin feeling, then obvously your going to get it elsewhere!
Im set up on 110/119/61.5 and after looking at tp21 on 61.5..and checking the channel chart, I dont see those channels mirrored on 110 or 119, so when they move to 77, will I lose them ?
hope I read things wrong...
edit - it appears the additions to the new HD transponder on 110 match the channels on tp21-61.5. doh.
