alrighty... try this..
Download this
http://plugin.slingbox.com/downloads/msi/1.4.0.117/WBSP_IE_Setup.exe
Then close all IE browsers and uninstall the plugin for IE through Add/Remove programs in the control panel..
Then run that file ... the WBSP_IE_Setup.exe .. that's the newest of the new versions.. .117
the next time you to onto any of the sling sites (Dish Remote Access, DishOnline, *sling*) you will get two things at once.. get told you have to install the plugin ... and should get a InfoBar .. if you carefully read the info bar it should say "...wants to run ..." (not the download info bar type) you can choose all sites.. or "allow this site" ... your choice... I only allow it to run on dish's & slings sites .. so I will manually allow only those sites to use it.. (by *not* selecting the "all sites" choice)
Anyway.. after that.. refresh your window if you need to.. and see what happens..
Download this
