We've completed our third round of tedious attempts to get this working. I'm far from a professional but did install my own satellite a couple years ago and then after cancelling Dish Network I repointed my dish to 61.5. I didn't have much trouble before and didn't think we'd have any troubles. So much for thinking.
We cleared the matrix, we adjusted the mast to be plumb using the level on both the west and north side of the pole and on the horrozontal of the bracket (it was off slightly at first). We've checked all connections with other electronic components and are connecting directly to a small tv with just two sections of cable a total of 9 feet or so in length (one section is RG59 instead of RG6 but everyone says it should work that close to the TV). We've made sure we are using the satellite in connection on the system. We moved the dish in very small increments (1/4 inch or so) and stopped between each move. We're not in front of the dish. We have changed the elevation in increments of two degrees from 31-37. Our angle here is 34 (66736 zip code) and that's the angle I use at my house across the street. We've connected his lnbf to my system and received a signal. We've connected his system to my lnbf and dish and received the signal. And in this most recent round we used my lnbf on his system and dish to try and get it set up because his lnbf on my system had shown errors on the one lnbf while the other worked. We thought once the phone not being connected could be it so we kept that plugged in over the last 2 rounds. It's all been to no avail.
What are we missing? This last round we did bypass the grounding block, but don't see how that could be it. I read once about coverning the unused side of the lnbf. Should we do that? Is there anything else to check. The dish we have is old but it was used as little as 3 months ago for the 110 & 119 dishnetwork programming and worked fine. It can't be the dish itself can it. It's still got a good coat of paint on it. We did have troubles with my system finding his lnbf at one point but after restoring the factory defaults and running a check switch test for 61.5 the system found it. Thanks for any more ideas on what we may be failing at.
