Dish 211 receiver .... best lnb and switch ???
Aguijon
Dominican Republic
Hello:
I have a 211 dish receiver and I want to know wich is better lnb and switch for it using only 2 satellites (110 and 119)???
Can i use lnb dish pro with this receiver with an SW21 switch????
In case of I want to take 110, 119 and 61.5 satellites signals.... which is the best switch and lnb for it????
Thanks.... your help will be appreciated.
Are you using two or three separate dishes? If all three are DP lnb's, you could use a DP34, DPP33 or DPP44 switch. If you are using a standard Dish500 dish, a DPtwin or DPPtwin would have the switch built in. Please note that a sw-21 will not work with DP lnb's, they would need to be legacy lnb's.
SW-21 indicates a Switch designed for LEGACY ELECTRONICS using 2 inputs to 1 output. A DP-21 switch is for Dish Pro Electronics again 2 inputs to 1 output.
You are probably using 2 larger non DISH dishes, most common usage would be using 2 generic LEGACY LNBs for 110 & 119 a SW-21 would be the appropriate switch.
Tech Srevice
hdcp now only in 4x3?
