Dish 119
yallayallah
Canada
Hi i need help to get signal for dish 119 i hv a dish 500plus with hd lnb 110 118 119 i got signal for the 110 and i'm not getting the others i tryed very hard and it's very hard to get it i'm using and old receiver to catsh the signal
On top of being from CANADA it appears English isn't even a second language. Try posting your equipment and real location. If you do have a 500+ you don't have a HD LNB that would be a 1000+ and add the 129 satellite.
You may be getting 110 through the wrong lnb. Look at the bottom of lnb connector to the arm, it should tell you which lnb is for which sat. Cover the one for 119 and see if you still get 110. If you do, try adjusting az and skew. If you don't, then your aim is off about 9 degrees. Note that is dish is not for HD also, Dish will not provide service to an address in Canada.
PTAT (Olympics) Records thru Loss-of-signal; Playback stops at LOS
Duo 625 to Hopper
