So my Dish 1000+ has everything installed correctly. I can verify this in the receiver (VIP222k). When I perform a check switch, I get 110, 118, and 119, but I do not get 129. All the 110, 118, and 119 channels work perfectly. I was under the impression that if I had 110, 118, and 119 working, then so would 129.
When I hover over the 129 sat number in the signal meter menu, I get signal below, but when it locks on it says 119 and says something along the lines of "wrong satellite". The 110, 118, and 119 locations lock in the appropriate satellites.
It took me a very long time to aim this dish, which was initially a 500+. I thought that getting 129 would be as simple as just connecting the new LNB. Apparently, it's not that straightforward. I'm using a DPP44 switch and I assure you that everything is hooked up properly.
So, if one has 110, 118, and 119 locked in, is there (generally speaking) a simple trick or twist of the dish that will make 129 lock on? - For example, increasing the skew by so and so much should make the 129 lock in while at the same time not losing the other sats which are already aimed right and working?
Thanks!
Thanks!
