Dish 1000 + 61.5 install help
ericcurtis76
5
Atlanta, GA
I've just started researching this and thought I'd ask the knowledgable folks here for some help.
I want to have Dish 1000 and old Dish 500 to pick up 110, 119, 129 & 61.5 and serve three receivers (622 and two 508's). Since only the 622 needs to see 61.5 (for Voom), can I get away with a DP 34 switch and DP 21 switch instead of spending the money for a DP 44?
If anyone can point me to install diagrams for such a situation, that would be very helpful. Thanks.
Eric
Voom is also on 129 so you may not actually need 61.5.
To get four sats on the 622 with a DP34 you'll need two DP21s and two cables to the receiver.
Cascading the dp-34 and the dp -21's wont work for long so dont do it, spend the money to get a dpp-44. The HD channels are on both the 61.5 and the 129 and if all your doing is putting in the 61.5 to get the hd then the 129 is a waste of time unless your locals are on it. The 61.5 will give you a considerably higher strength signal over the 129 sat so I would recommend going with the 61.5 sat if you can.
But still I would not go the route of cascading the two switch types together, its not supported by dish and was part of a recent memo stating that it is not supported and that the switch's will burn out.
I do not know why so many people here recommend the cascading of the DP 21 with the DP34. I tried it and it did not work for me....but, I only had one receiver connected. It worked for about 2 days, then the receiver started rebooting. I called Dish, they sent me another receiver, but the new receiver only saw one satellite.
If you really want four satellites, you need to get a Dpp44.
i have cascaded switches (DP21's and DP34) on my own setup for quite a while, and have never had a problem with it... just my experience with is
ps.... as an installer I can't remember any time i've done it at a customers house, just my own..
Downgrade online
Dish 500 Question?
