Hello,
So I started getting "drift" notices, did a huge amount of research and decided that the triple lnbf was failing. Ordered the 1000.2 antenna, new WA triple lnbf and I will soon be ready to install it.
I bought a "cheapO" signal meter from radio shack. I am still a bit confused about peaking the signal and where. The instructions say to use port 1 (far left on the lnbf) and peak 119. Will I still have to cover the other two lnb's with aluminum foil to do ths or since all of the integration there is no need for that?
Since there will only be one reciever connected, I can use port 1 to the reciever after the dish is pointed correctely? I assume with the integration there is also no need to jump port 1 to 2 ... and 2 to 3, right?
Thanks,
RBDay
Thanks,
RBDay
