I'm setup my D1000.2 last night in anticipation of signing back up with dish in a month or 2.
I still have a 301 receiver that I was using for pointing and setup testing and I am not sure if I have a problem with my 301, D1000 LNB, or DPP44 switch.
here is the orignal setup
D1000 --> DPP44 (119, 110, 129 on ports 1,2,3) --> 301.
Do check switch and all looks good.
However, when checking signal strength, I never get a signal on the Odd transponders on any of the 3 sats. Evens all come in nice and strong.
So I try just wiring directly to LNB and all is fine. So I figured I had a bad DPP44. Since I was using my old DPP44 and a new one came with my D1000.2 purchase I decided to swap out the switch.
Swapping out the switch produced the same problem as before, no odd TP's on any of the sats.
Anyone ever run into this? Since I am only planning a couple DVR's and the 301 when I go back to dish, I am good with just the 3 outputs from the LNB, but now I am curious what is going on with the DPP44?
Also, the 301 is updated to current software and it used to work fine with my D500 hooked into the DPP44 when I last had dish.
