DIRECTV Transponder Map ~ Data 1/1/2025
Seattle Kraken announced they are leaving ROOT NW for OTA, signing with TEGNA, games airing on KONG, select few simulcasting on KING5 NBC, KGW NBC in Portland, KREM CBS in Spokane (don’t know yet if they will be on subchannels), and Amazon Prime across the team’s territory… more affiliates to be announced
Looks like we will see some Kraken games instead of all to air on DTV’s NHL CI next season
The networks will never let them pre-empt network programming most nights of the week for the entire fall-spring TV season, so they will primarily be on subchannels in Portland and Spokane. It will probably pre-empt True Crime on their .2 channels
Reactions: lordodogg
DirecTV Satellite Transponder Updates for May 01 2024
Comparison of Transponder Data for May 01 2024 vs Apr 24 2024:
No changes in system tables for any transponder tuning parameters.
Changes to the use of defined transponders:
1 Transponder cleared of all Streams::
Net 0 TID 17 Beam RB05 is a Spot Beam Transponder on D9S@101, TPN 18
On 04/24/24 this transponder serves DMA 39-Chicago, IL
1 Previously unused Transponder with current APG records::
Net 0 TID 17 Beam NAT + PR is a National Transponder on D16@101, TPN 18
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
275​
1450​
SD mpeg4
139​
202​
SD mpeg2
422​
11​
104​
-14​
RB​
Audio​
89​
Push​
31​
Slate​
20​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
3​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
45​
3​
2​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
A few SD_LILs shifts
TPN 18 cleared on D9s and made National +PR on Sat D16
Weekly analysis soon
Enjoy
Data Digesters
Reactions: Scott Greczkowski
Some TPN reshuffling involving NFLHD, MGMHT and NSCAHD (This actually happened late last week, so it was likely NFL Draft related)
CINE 183 has returned, pointing to the same feed as CINE 177
More Roland-Garros prep
SHOPHQ HD's label has been updated
The existing targetted offers have been removed, replacement ones are testing (9751 Choice Upgrade Offer, 9757 MLBEI On Us)
Passing along Gracenote's OTA record cleanup for KSTC and KDOC
Scripps News will be replacing Bounce tomorrow on the secondary Ion LIL stations KILM/64 Los Angeles, WFPX/62 Raleigh, WDLI/17 Cleveland, WSFJ/51 Columbus and WCLJ/42 Indianapolis.
Bounce will still be available via channel 82, and for those not paying attention to the FAST thread, a few weeks ago Scripps News was added to channel 4009 via the app and website.
As of last week, the only spot beams active were on TPNs 12 and 20. Although those transponders have not yet been shut down, tioday's guide data shows only the spot beams for New York and Minneapolis being used, on two transponders using the TPN 20 frequency. This morning I still see a signal on TPN 12, but it is no longer being used by the guide data. I expect one of those two markets to be remapped to a national transponder on TPN 12 and the other transferred to a national TPN 20 transponder on D16 in the next few days. DirecTV will then prepare D9S for transfer to a higher disposal orbit beyond the Clarke belt.
DirecTV Satellite Transponder Updates for May 08 2024
Comparison of Transponder Data for May 08 2024 vs May 01 2024:
9 Transponders cleared of all Streams::
Net 0 TID 11 Beam CB13 is a Spot Beam Transponder on D9S@101, TPN 12
On 05/01/24 this transponder serves DMA 56-Detroit, MI
Net 0 TID 11 Beam CB14 is a Spot Beam Transponder on D9S@101, TPN 12
On 05/01/24 this transponder serves DMA 81-Greenville, SC
Net 0 TID 11 Beam CB18 is a Spot Beam Transponder on D9S@101, TPN 12
On 05/01/24 this transponder serves DMA 51-Dallas, TX
Net 0 TID 11 Beam CB20 is a Spot Beam Transponder on D9S@101, TPN 12
On 05/01/24 this transponder serves DMA 169-San Francisco, CA
Net 0 TID 19 Beam CB14 is a Spot Beam Transponder on D9S@101, TPN 20
Net 0 TID 19 Beam CB17 is a Spot Beam Transponder on D9S@101, TPN 20
On 05/01/24 this transponder serves DMA 182-St. Louis, MO
Net 0 TID 19 Beam CB18 is a Spot Beam Transponder on D9S@101, TPN 20
Net 0 TID 19 Beam CB19 is a Spot Beam Transponder on D9S@101, TPN 20
On 05/01/24 this transponder serves DMA 148-Phoenix, AZ
Net 0 TID 19 Beam CB20 is a Spot Beam Transponder on D9S@101, TPN 20
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
4​
HD​
274​
-1​
1449​
-1​
SD mpeg4
140​
1​
201​
-1​
SD mpeg2
428​
6​
25​
-79​
RB​
Audio​
89​
Push​
30​
-1​
Slate​
20​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
2​
-1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
41​
-4​
2​
Weekly Analysis soon.
Sorry , I'm late
Traveled to grandchildren and time got away from me
Enjoy
DataDigesters
KAZF/32 Flagstaff (Arizona Family Sports) is finally testing for the Phoenix DMA. It's also testing on the stream server
The ex-CW subchannels WJHG-D2 Panama City and KSFY-D2 Sioux Falls have been dropped, along with the test records for KUGF Great Falls and KCBA Monterey-Salinas
9751 MORE (Choice offer) and 9757 GIFT (Extra Innings on Us) are now live
The SD locals for Dallas, Detroit, Greenville, Phoenix, San Francisco and St. Louis are now pointing to the slate.
A test offline record for 9363 FOX Weather, Merit Street now has a logo
For some reason, the offline FOXWeather test record is a little unusual. It does not state what satellite it's on at 101, and it's on TID 0, TPN 0.
No, actually if you use Excel or other OPENXL compatible spreadsheet program to look at the spreadsheet, the TID and PID are empty, not 0. That APG object is like one that showed up a couple of weeks ago in an Engineering test record. It is a new form of an APG binary object that we have never seen before. As far we can determine so far, there is no TID or PID in that object. There may be more information that our APG binary decoding expert has not figured out how to decode.
  • Wow
It's curious to me that Minneapolis has somehow survived all the way to the end of this project. I understood NY, due to both size and, I presume, that the SD locals are used in commercial environments - airplanes particularly.
This morning TPN 12 from 101 is a National beam, and the Minneapolis SD duplicate locals have been remapped to it from their Spot beam on TPN 20. That leaves only one spot beam transponder active on D9S, a beam using TPN 20, feeding New York City. That could easily be switched over to D16 at any moment.
