Hello,
I live in a very small area, in Wyoming. We only have access to a few local channels with an antenna, or cable, or even DISH, but DirectTV does not carry any. I just recently switched to Direct TV after a salesman incorrectly informed me that if I were to buy a very inexpensive ($34) indoor HD Antenna, I would be able to hook it directly into my satellite and access all the local channels through my receiver, and be able to use the DVR. Instead, so far, I have had to return the $34 antenna and purchase a much more pricey outdoor antenna, as well as an AM21.
I am now able to tune in to most of the OTA channels, but the guide is incorrect for every one of them. I am also still missing 2 of the local channels I would like to receive. I have reset the AM21 several times and repeated the scan. I have reset the DTV receiver several times.
I have tried to input several different zip codes, as described earlier in this thread. I downloaded the TPN Map and am using that to look up possible channel matches. (In fact, it lists the local channels from my area on the correct station, even though my guide does not). I have tried using the new zip codes as both the primary and secondary markets.
Nothing seems to work. Which leads me to a few questions...
1. When I reset the DTV receiver and go back into Antenna setup, the zip code I last typed is still there. Does that mean I did not properly reset the AM21, or reset the DTV receiver incorrectly? I am resetting them by unplugging for several minutes. Also, several times I have clicked on Reset Settings on the Antenna Setup Screen, but nothing ever seems to change. The last time, I actually checked the guide before going back in to ensure that the channels were no longer available. But my primary ZIP code was still there.
2. When I type in the various zip codes, am I supposed to be doing it in the primary or secondary market, or both? (I have tried each, but never both) If the secondary, am I always supposed to retype my primary zip code as the Primary market? Or can I try to use two different zip codes for each scan?
3. Am I supposed to uncheck the stations for which the guide is incorrect (under Edit Off Air Channels) before I do the scan with the new ZIP/ZIPS?
Thank you for your assistance!
