Went to bed last night with my living room HR-20 working fine. I woke up this morning, and couldnt get the unit to do anything. Wouldnt turn on with the remote or the buttons on the unit. I unplugged it and it started up fine. No problems. Just wondering if they did something las tnight to cause this.
Another guy at DBS had the same problem on his HR-21
HR21 would not turn on - DBSTalk.Com
Any ideas?
Reported problems (I will add more as I see them)
Unit wont respond until after a RBR (for some) or unplugging the unit
Favorties list is erased
Series links are erased
Resolution changed to 480i
Networking issues after reboot
Users reporting multiple reboots
Sluggish remote response
Two users reporting the problem with the R-22 also
Remote codes for TV erased
POSSIBLE HDMI output issue reported by one poster
A couple of reports of "channel not available" after reboot
Reports of lost recordings (possible limited to external drives?)
(At least one poster is saying it effected his old Tivo box in some way)
Hanging up on 97% after reboot in some cases
Incorrect clock times
Guide only shows channel that the DVR is tuned to
System locking up after you choose delete recording
Many posters having to reboot a few hours after doing it the first time
Many reports of locking up again (around 11:45 central time)
Cooling fan running at full speed before reset
Any ideas?
Update from post 100:
Here is the official response from DirecTV:
There was a broadcast anomaly that was causing this problem and a fix was put in place at about 2:35 PM ET. We are sending out a re-set this afternoon to boxes starting on the East Coast that should resolve the issue.
Any boxes that were manually reset after 2:35 PM ET should already be working normally.
Rememeber, if your getting home from work - Your box will need to be manually reset the first time, then it may reset on its own again upon receiving the fix from DirecTV.
The issue was not a software version download, there was no new software sent last night. The issue was something in the broadcast.
UPDATE:
Just received word they are rolling the fix out to the other time zones.
Again - DON'T be alarmed if you box reboots itself.
