- Sep 9, 2003
- 12,308
- 2,007
a friend asked me if D* has a DVR that will output HD to a second TV. I know very little about the D* lineup so i will ask here if there is such a DVR.
I am assuming that my friend misread or misinterpreted something. thanks again.
The closest thing is that all outputs are active so one TV could run HDMI and the other component and use an RF remote from the 2nd set.
Alternative is to check out Multi Room Viewing testing going on in the CE section. Using ethernet wired/wireless/powerline HD DVR's and HD non-DVR's that are network connected can view recordings from the HD DVR's.
Both DISH and Directv receivers only have one HD output per receiver.
They output one hd signal, but there is an hdmi and a component output, both of which are live.
What model receiver do you have. The HR series ships with a RF capable remote, you just have to change it in the menu of the box. I think the H series does as wellI'm doing 2 HD TV's in this manner with a 30' HDMI cable running the far set in another room and components to the set by the HD receiver. To control the HD receiver in the other room, I using one of those IR-->RF-->IR sets that I picked up at Radio Shack for around $40. Picked up an extra remote on eBay for about $8.
Got my HDMI cable at monoprice.com. They also have a model similar to the Radio Shack IR extender.
The H2X's can do RF remote but they don't ship with one, you need to buy one, about $25.00.
All 5 of mine came with an RF remote.
I am PRETTY sure that at least one of the two H series that I had before did . I know I have at least 3 RF remotes in my house, and I have bought noneThe H2X's can do RF remote but they don't ship with one, you need to buy one, about $25.00.
Ok, that explains it. I had the 20sI take that back, my H20 that I purchased when it first came out did, but the H21's didn't.
I have generally found the opposite to be true, but I guess every situation is different.
Regardless, the RF remote doesn't have enough poop in it to reliably signal my receiver from another room and the Radio Shack model does. (IR--.RF--IR)
