I have a single LNB (a fold-up, manual crank dish on top of my RV).
I'm not in the market to replace that dish, they are very expensive.
I currently use a standard def receiver, it works fine.
I have a standard def dual-tuner DVR that I would like to use. I understand that it may be possible to use a splitter, with one power-passing side, to split the single LNB to feed two tuners.
I also understand that the power-passing side would select 13V or 18V and that the second tuner would be limited to the channels on the voltage that the primary tuner has selected.
So, if this is correct, is there somewhere that I can find a list of the channels that are broadcast on 13V and 18V?
Also, what specific product should I use for the one-side power-passing splitter?
Thank you.
Thank you.
