I have 4 lines coming off my slimline dish and I want to get more since I now have 2 DVR's and 2 other receivers. What piece of equipment do I need to turn 4 inputs into 8 outputs? TIA.
WB68 works great for me with 6 outputs. Two of them are pretty long runs partially using my old RG59 from cable days. No issues whatsoever.Since the WB68 isn't powered, it is probably a bit more picky about the voltage levels, so using coax with a solid copper core is more critical, as is total line length. Directv should supply and install one for you at no cost.
I've read some threads from other boards about the WB68 being not so reliable. Is it worth the extra $ for the WB616?
I've been running a WB68 for about a year with outputs without any problems. However, I probably will take advantage of the new lower price for the HD DVR and replace my H20 with a HR20/HR21. I will need 9 outputs then. Can two WB68s be daisy chained together or would I be better off getting a WB616?
