DirecTV 10 Signal Reading Thread(Transponders are Hot!)
I am watching the live continuous stream on Transponder 11 for the past hour. Its been dropping to zero a few times but only for a split second.
H20-600 Transponder 11 on 103(b) only 96
in norwalk,ct.
I got a 99% on TP 11 Here in Wayne County ,Pa,on my HR20,but a zero on my H20. I wonder why?
you will probably have to go through the sat set up again - when you set it up it probably did not see the 103b location and gave a failed message. that should work for you.
On your H20 are you waiting long enough on the test, the H20/H21 are VERY slow showing readings on the Ka satellites?
9300 Now A&E
Still searching...
