Dave nye said:
Juan,
This is a High Def receiver. They do not display the local channels the same. If you had one you would know this. Local channel 6 will show in the guide as 6-00. You can't just type it in, unless you type in the corosponding number that will be in the 87## range.
No David. Juan is correct. (As is BFG.)
Typing 006 will take you to the first channel 6 in your receiver. If your 811 is configured for Dish Locals in 02-99 range, it will take you to the Dish provided channel 6. If you have only OTA in that range, it will take you to the first channel 6 you have programmed. If you have analog OTA programmed in, it will be analog channel 6. If you have only digital OTA, it will be 6.1.
BFG explains how to go directly to a Dish, analog OTA, or digital OTA local channel, typing 00600 will take you to either analog OTA channel 6 or Dish channel 6, depending on your 2-99 setting. 00601 will take you to 6.1, 00602 to 6.2, etc.
Here is another wrinkle. IIRC with my 811, I only needed 4 digits. (3, if I wanted the analog or Dish local. Adding the fourth digit would just make the channel change quicker.) 006, 0061, 0062, etc. Can anyone with an 811 confirm the last paragraph, in case my memory is faulty?
