Is it true that I cannot diplex my OTA through an AT-9 set-up? If so, does that mean I have to pay D* for something that I can receive for free...unless I run more coax to each receiver??
Yes it is true,jimmiepens said:Is it true that I cannot diplex my OTA through an AT-9 set-up? If so, does that mean I have to pay D* for something that I can receive for free...unless I run more coax to each receiver??
damaged said:That is correct, you cannot diplex with AT9, as it occupies the frequencies used for the diplexing channel.
And no, you don't have to pay D*, you can run your own line(s).
If D* provides your HD locals via the AT9/H20, than, as far as they are concerned, you got the HD locals they promised, and, uuless I am mistaken, they may or may not install OTA coax for you free. Now if the ONLY way to get your locals ARE via OTA, than D* would most likely do it free without asking.
EDIT: Jimbos beat me to it.
jimmiepens said:Running another line to 6 receivers spanning 3 floors(with no crawl space)is not going to be cheap, unless I lay it across the carpet, up the steps, through bathroom, draped over the chandelier...you get my point...
I bet you can still run them yourself MUCH cheaper than D* will charge you.jimmiepens said:Running another line to 6 receivers spanning 3 floors(with no crawl space)is not going to be cheap, unless I lay it across the carpet, up the steps, through bathroom, draped over the chandelier...you get my point...
Jimbos said:I don't think I would expect them to run the line for free, if they do thats great, just don't ecpect it...
Jimbo
damaged said:Agreed, I wouldn't count on it, sorry if my post sounded otherwise, the OPs chances of success depends, among other things, their account status, and how bad D* wants you as a customer, etc...you know the drill. Also, one line, maybe, 6 lines, that is another story.
johnml said:I just had my dish replaced with a AT9 today and the installer didn't run a separate cable to my HR10, he left it hooked up to the multi-switch.
So, they are sending someone out next week to run a cable they should have run today. because of this they are also giving me $10.00 for six months because of my inconvenience, So I'm a happy camper. Also they installed a OTA antenna 2 weeks ago - the networks here in south Florida are both UHF/VHF, so i cant get a few with the UHF antenna they put up so they refunded the $49.00 i paid and also gave me a $75.00 credit to buy my own antenna - Guess they were in the giving mood today. Somebody up there love me huh ?
Check Home Depot, Lowes , Radio Shack they carry name brands.,unless you have a OTA antenna company around, though they may cost moreraoul5788 said:Check this antena out. Probably about what you will need at a good price, too! You might be able to find it locally.
http://www.solidsignal.com/prod_display.asp?PROD=ANC3679
Jimbos said:Check Home Depot, Lowes , Radio Shack they carry name brands.,unless you have a OTA antenna company around, though they may cost more
Jimbo
Personally, if you can afford it, get the rotor also, it will come in handle from time to time, sometimes I will have to move it a few degrees one way or another... Digital signals need to be closer than analog for a solid signal.raoul5788 said:I just checked the Lowes website. They have the Channel Master 3018 at the Oakland Park store for around $60. It's worth checking out. IIRC, you already have a pole. All of the Miami/FtLauderdale stations are from the same direction, so you shouldn't need a rotor unless you want to pick up the WPB stations, too.
Jimbos said:Personally, if you can afford it, get the rotor also, it will come in handle from time to time, sometimes I will have to move it a few degrees one way or another... Digital signals need to be closer than analog for a solid signal.
You'll be happier in the long run, I can't imagine running up on the roof with tools to adjust my antenna each time I wanted to... Of course I use my rotor regularly to pick up Detroit often and CBC Canada during hockey season.
Jimbo
Hoss said:I guess I am confused. I had the AT9 installed a month ago (with the H20 receiver) and I am still receiving my OTA channels through a diplexer. I live in Phoenix and I am getting the HD locals from the AT9 as well. Am I missing something here?
