Hello everyone,
I'm brand new to this forum and hope to get your thoughts on a possible configuration.
I currently have DirecTV service with the Slimline dish and the SWiM and DECA. The configuration is as follows:
Dish (1 coax line) -- 3-way splitter (outside) -- SWiM (on one of the outlets) -- DECA. Only 2 of the 3 outlets have a receiver, the third outlet only has the SWiM and DECA hooked up. The DECA is hooked up to my internet router, which is connected to DSL. So far so good, everything works great.
I now want to get cable internet for various reasons. Since I can't run any new wires, I was thinking about diplexing the cable internet signal as follows:
Dish (1 coax line) -- 3-way splitter (outside). 2 of the 3 coax lines will run directly to the two receivers that I have, one of them having the SWiM in between. The third coax line from the splitter will run into a diplexer, with the second feed being Comcast cable internet. At the third outlet, another diplexer will separate the signals again. The non-satellite output will run into my cable modem, which is connected to an internet router. The DECA will be connected to the internet router and the coax will run into the sat-output of the diplexer and supply the two receivers with an internet connection.
At least that's my theory. My question is: could this configuration really work and if so, what kind of diplexers will I need ?
Thanks in advance, and please let me know if you need additional information.
Dan
Dan
