Diplexers and Splitters
Edmundo
35
This is setup:
Family room has the OTA cable and FTA cable
Master bedroom has Coolsat 5000
One cable between both rooms
This is what I'm trying to accomplish:
I want to be able to view same program (Coolsat) on both tv's
Feed my MB TV with OTA
I plan on buying 2 diplexers and 2 splitters. Is there any hope that this will work?
I've seen different diplexers and splitters on Sadoun page, which ones do I need to buy?
Sure will work, with Diplexers you can combine satellite and cable and send the signals back and forth in any direction!
I would use the RCA outputs on the Coolsat for your TV in bedroom (If you have RCA connections on the TV)
Then send the satellite signal back down the same line that the OTA signal is coming from with the use of a Diplexer at each end of that cable.
So you will have OTA coming from the Family room and going to the bedroom and Satellite signal coming from the bedroom to the family room.
So really two Diplexers will work! ( I would get the splitters also as they are handy)
Thanks Pete!
The reason I mentioned the splitters is because I think I need to combine 2 coax from my family room: 1 with OTA and 1 with the satellite signal. Once combined, I would connect it to the dixplexer on one side, and on the other the satellite feed. Once in my bedroom, the OTA would be connected to the splitter, one side to the tv and the other connected to the receiver out.
Will this work?
ChannelMaster Dish
New!
