Digiwave Diamond / CoolSat 4000 Pro TVGuide
regisma
58
Hi,
I have the following questions when I use my Digiwave Diamond.
When I use the Guide button it lead me to a screen divided in three major parts (upper Left the detail info about what is currently playing, upper Right a small image of what's playing, the bottom a guide of channels and the time the show is playing.
How can you "scroll down" the info showed in the top Left section of this guide?
Also When you change from channel to channel you see for about three seconds bar that show the channel no, it's description, the signal quality, ..
There are a series of small circles that somethimes displayinfo such $, ...
Can someone can describe those ? ($ mean PPV but what mean the other?)
thanks
Regis
Hi, Guys,
I know those the one, I do not know is shaped as concentric circles and one shaped like a sheet that have a sheet that have been of tears apart by example.
And does someone have found the trick to scroll down in order see all the info of the show you are currently watching when you use the guide button?
thanks
Regis
Hi,
I have found the button that allow to scroll down while watching the info of a show.
You use the GUIDE button and you use the GREEN button to scroll down the program description (the Top Left Window).
thanks
Regis
lowest angle for birds
AC3 Audio
