I called dish, and upgraded to a 722k. They sent a 722 instead. Are there any differences? Should i send it back? Im going to get the sling adapter, and i want to be able watch content from my ehd with it. Any differences with the on demand?
whatchel1 said:The K is different. The remotes are different and will store the timers on them. The K comes w/o the OTA. You have to purchase a module for that but it will record 2 OTA's at the same time. This makes it possible to record 4 things at one time.
You don't even need the Sling Adapter to view the OTA on TV2...after starting your OTA recording, just watch it from the DVR (chase play) from TV2 via the distribution coax. (SD only)I have been very happy with my non-k except for one little gotcha. I can't tune in OTA channels from TV2, even when the tuner is not being used.
And BTW my 722 runs my Sling Adapter just fine. Plus it gives you a workaround to the missing feature above. You just start up an OTA recording, and then play back the recording via Sling Adapter with a few seconds delay. Annoying workaround, but it works.
Ota is a non issue for me. Any other major differences?
If you are going to use the sling, you need the K model.
You don't even need the Sling Adapter to view the OTA on TV2...after starting your OTA recording, just watch it from the DVR (chase play) from TV2 via the distribution coax... You have to set the timer from TV1.
I think that the 722K remotes are way better with the timer backups, learning ability, plus they look better .
If I have a 722 receiver but with 722k remotes, will the timers still backup on the remote?
One other (minor) difference...the 722K does NOT have an S-vid output...I called dish, and upgraded to a 722k. They sent a 722 instead. Are there any differences?
Unfortunately, no .
I'll just chalk it up to me being tired last night more than you being unclear.Was I unclear?
Deal breaker! Half serious, as my HDD/DVD recorder is currently connected to the s-vid output.One other (minor) difference...the 722K does NOT have an S-vid output...
