Hi everyone, I'm hoping to get some advice and info on my installation. First let me say I only have a very basic understanding of the equipment and the networking technology it is using, so please excuse me for any stupid questions. Everything is working right now, but I've already had two instances in the past couple weeks where my entire home network went down, and I had a really hard time getting the modem/router to work again. I'm not sure if the problem was the cable company since it's also a new install, or if the issue arose with the router due to the things I'm about to describe.
Here is a list of the equipment I was told I had installed:
HR34 HDDVR - Family room
HR22 HDDVR - Master bedroom
DECA box - Family room
Cinema connection kit - Master bedroom
I have since also installed a new wireless router, a Linksys EA4500 using DHCP that is connected to my cable modem - Basement
The installer did not seem interested in hardwiring any of the components (even though it would have been fairly easy as the basement is unfinished), so everything is connected to my home network wirelessly. And that is where I have concerns and questions. I was looking online for info about this stuff, and found some disconcerting things about Directv not recommending or supporting a wireless setup. Should I insist on it being redone with some or all of it hard wired?
When I look at the router device list in its configuration, I see an entry for the HR34, HR22, decaw, mediashare renderer, and a "network device" also appears. I am wondering if it is normal for the mediashare renderer to mirror the same IP address as the DVR's, as I've seen it alternate between those two device's IP'?
And the mystery "network device" that the router doesn't identify (assume it is the cinema kit?) seems to bounce around IP adresses as well, but at this writing has the same IP as the HR22. I would have sworn I saw it grab the same IP as my laptop earlier today while the laptop was in use, so I've since put in DHCP reservations on most of my devices (excluding the Directv equipment that seems to be sharing IP's, since that seemed to break the MRV functionality). At first i didn't know what the "network device" entry could be, as it has a weird Mac address of FF:FF:FF:FF:00:00, but do you agree it must be the cinema kit? So I'm wondering if these duplicate IP's are to be expected, or if they can cause issues with the router that would eventually cause it to shut everything down again?
I appreciate any and all advice, thank you in advance for your input!
