bestspartan said:The only local specific issues I have are:
1. Local Fox station looses HD signal often. I don't understand this since I live only appox. 7 miles from the broadcast ant.
2. WB still not broadcasting in digital?
Slick said:Hello everyone do you guys have the number and location of the Don Lors Electronics? I live in Saint Clair county right near the Saint clair river and I want a competent instaler and it sounds like you guys have had good luck with them.. Thanks Slick
At 47 miles you need to get an antenna upgrade from VOOM. Many seem to have gotten either an upgraded Winegard or a Channel Master 4228 with a Channel Master 777 pre-amp. Call VOOM and they will set you up with an antenna upgrade with your installer. Often because of atmospheric conditions at night digital channels will come in at night but not during the daytime.... not uncommon. With a better antenna you should be able to get all your channels day or night. Tell VOOM you want the Channel Master setup.....Slick said:Hello there Detroit Voomers I had my Voom installed the other day by Dn Lors and they did a great Job, and I love voom so far but I have one question.. What OTA antenna did they use on your instalations? I am having trouble getting my OTA channels from Detroit which I am 47 miles away, I can get 2,4,7, at night and thats about it, during the day forget about it..
Sean on this site helped me try to figure out which one to buy but I would like to find out what OTA they used before I go and buy another one.. This is what I know it is a Winegard and it says amplified on the antenna itself and there is no pre amp in the rg6 cable between the antenna and my tv just a splitter.. The description of the antenna it looks just like a 2' wing with the same pole mount as the dish.. ANY IDEAS? Thanks guys Cya Slick
