Installation did not proceed as planned. The installer arrived and shot down my roof mounting plan... said that mounting on a metal roof was against company policy. That knowledge would have been handy when I told the salesperson that I wanted a roof mount. After we walked the surrounding area and chose a spot for mounting on a pole, he could only produce one about 3' long. This was the last thing I wanted, if I had to settle for a pole mount, I wanted it at least out of head-banging reach. He looked at an old 4x4" landscape timber clothesline post as an option, but I'm sure that my wife didn't want to give up her well-established trumpet vine that had taken it over. So, he left the ground pole up to me, gave me the hardware needed to bolt up the dish and proceeded home.
I discovered that he was right, a 2" OD metal pole would not be easy to find. I bought 2" EMT conduit, but even that slightly larger than 2" OD was too much. I was ready to get muffler pipe at $4 a foot and sand mix concrete for the center, after concreting it in the ground.
Rethought the whole problem. Not only was I settling with putting the dish where I didn't want it, I was going well out of my way to get it there. Made a couple of phone calls and found the solution:
The Dish installer put it on the edge of my deck roof... it is mounted on an overhang so that if for some reason it would start leaking, it won't even affect the deck below. I reinforced the base underneath the steel sheet metal between the rafters, so stability shouldn't be a problem.
I sure wish I could have went back to Directv. I had set up the AAA discount and referral for my 79 year old mother, and couldn't equivalent discounts with Dish. But for my family's viewing, Dish suited us better, even after blocking all of the shopping/bible thumping/special interest channels. I will never take advantage of the sports packages of Directv. I was firm on not spending the extra $99 for the HR34, and didn't like the option of settling with whatever HR23 or lower, reconditioned receiver was on the installer's truck. The hopper/two joey setup is a little flakey, but hasn't given us any issues so far, the tuner limitation compared to the HR34 will not be a problem with us. Without using primetime anytime, the 2TB hard drive was 25% full after 5 days, so the smaller HR receiver drives would have been a disappointment. And, I would give a word of advice to installers out there, to blindly follow company policy and refuse a metal roof mount, regardless of the individual's situation and needs, is short sighted.
