Had my service installed last weekend and according to the installer they didn't send the right parts to hook up the DECA. So he had them ship me the parts.
I have a SWM setup with MRV. There is an 8 port switch where all coax ends. 2 HR-24s and 2 H24s.
After looking at a bunch of diagrams online of the DECA setups, I was under the impression I'd get a DECA adapter like the one below plus the power adapter.
What I ended up getting was the adapter below. I haven't seen this before so I did some searching w/o much luck. Based on what I read, it will work with my setup, but I just wanted to make sure. It does have a power adapter that is not pictured.
So i'll plug the Ethernet wire coming from my router into the adapter. Then run a coax from the adapter to the switch (Installer showed me which port/connection to use). From there I should be fine? Or is this the wrong part?
Why do I only see the white ones when I search around?
