DECA Broadband Adapter & SWM Power Inserter
steve952
14
Minnesota
Does anyone know if there would be a issue having the pass through output of a SWM power inserter feed a broadband deca vs the HR-24 that is currently hooked up? My 2 year old is obsessed with unplugging the power inserter so I'd like to move it to the utility room where the broadband deca is, I know I'd have to switch the coax around on the splitter to move to the power passing port, just curious if the broadband deca would work properly behind a power inserter.
As long as the power inserter goes to port 1 of the splitter, and it is wired correctly - jumper to DECA goes to "To Receiver" port, and the cable from splitter port 1 goes to "To SWM" port, it'll be just fine. Just remember though, the DECA still needs its own power connected, it will not pull power from the inserter.
Have you ever noticed
Sat 99 c odd
