Curse you D*!! A few ?'s...
the_Drake
28
Here's my situation. I just upgraded to HD+DVR and the HR20 had audio issues on HD channels. I got a replacement reciever, a -700 model unlike the -100 initially. I don't care about the difference, so that's not the issue. So, I got it up and running and lo-and-behold the audio issue is gone. YAY! Problem fixed. Well, I wasn't getting a signal through my HDMI, so I had it up through component. After making sure it all worked, I unhooked it to check the HDMI and noticed one of the connectors was missing. So no HDMI on this unit, ever. I can live with running through component, but I noticed a better picture in HDMI mode, especially at 1080i.
Would it be worth sending in for another unit? What are ya'lls preferences on connections? HDMI or component for HD?? I have enough inputs, so it's really not a problem, just me being OCD :)! I am concerned about new HD programming coming out being protected, HDCP, so will that be an issue if I am not running through HDMI?
Well, I'll await your responses.
Thanks for the input!
Let me get this straight...you got an HR20-700 and it didn't have an HDMI output on it? Only component? Didn't think there were models without HDMI...
I prefer HDMI since it carries audio as well, but when running through a Home Theater system, the sound is split off anyway. If you are OCD, then HDMI would be the best bet since it is only one cable as opposed to three ;) But either way, you will get a quality HD signal (assuming the cables are in good shape/no shorts). This is just my opinion, and is not based on any scientific evidence, so take it with a grain of salt... :)
:welcome to Satelliteguys Drake!!
I think he means one of the pins...not sure.
Thank you ke4est! To atp, I do have the HDMI, but as ke4 said it is one of the gold pins/connectors. I took a flashlight to it to see what the deal was, and at first it looked like it was just bent, but on further investigation I noticed it was sheared off, so no signal.
After watching for a bit I noticed that 720p looks pretty good on the component, but 1080i is blah. I like the 1080 coming from my upconvert DVD player, and the other HR20 looked better on hdmi 1080 than component.
Absolutely HDMI. Even on my lowly 720p TV I see a very noticeable degradation using component. Don't settle for faulty unit. Make them give you a replacement.
Depends on the TV, but go HDMI for sure, and get another box to enjoy it. For me it's a BIG difference.
Won't D* simply send you a replacement HR20???
Yes. I called them and they are sending yet another replacement. Mainly I wanted to know what other people were using as an output, whether HDMI or component. I have determined that I like HDMI better, especially at 1080i. The component just doesn't cut it.
Remote code for HR20 to be used with Universal Remote
Seattle KIRO?
