Cracked LNB
chazcbh
174
Has anybody had a problem with the AT9 dish and a cracked LNB? It is the only think I can figure happened. On Friday 4/14 is was raining most of the day and all of a sudden I lost singal on most of the 101 transponders. They were in the 90's and they went into the 20's or zero. Searching for sat on several stations. All HD still worked and some movies. All locals also worked.
Called DTV they will be here Monday morning.
On Sat 4/15 it was sunny & 80 and the signals started to return and all stations are back on???
Has anyone else had a problem like this?
Not necessarily a cracked LNB. I've seen many cases where moisture will get into the connections of the LNB, and cause - for want of a better term - a short.
Either way, the tech will probably replace the LNB. :D
Well there was nothing wrong with the LNB the Dish just moved out of alignment.
Some how the one of the support bars came loose and the dish moved down a bit.
AT9 Physical Measurements
Any way to get new subscriber discounts over their normal offers?
