Greetings,
I would like to know what are the correct setting to use in the antenna setup screen in order to do a perfect ( or near perfect ) blind scan ?
My current setup is :
- stab100 motor
- 1m winegard dish
- invacom qph-031 quad lnb
- viewsat ultra
For now I am using the default setup to blind scan. However, this has the following drawback:
- Long blind scan ( 30 minutes ). The viewsat is scanning both low/high
on H and V and this take a very long time. I suspect I am scanning too many
frequency and that could be speed up by a better setting
- Duplicate channel ( or 3/4 copies of the same channel) on different
transponder.
- Transponder mismatch. The viewsat report an active transponder ( and active
channel ) on number that doesn't match those provided on lyngsat. Here we're
not talking about a few digit mismatch. For example, I got transponder on
10,884 and 11789. Both contain the same channel list. Those are not the real
number, just an example to show you the difference bewteen the number.
I suspect that this is all related to the default parameter used for blind scanning.
Anyone have the correct parameter to use with the invacom for scanning a FSS/DBS bird ? The setup must be different for a FSS than for a DBS sat. At least I think soo. But I may be wrong. This is all new to me. And I am seeking your help.
- stab100 motor
- 1m winegard dish
- viewsat ultra
transponder.
