Cooper Nuclear Plant. Fort Calhoun NE
With all the heavy rain around here, things are finally starting to heat up! The flooding along the Misuori river has forced officials to build a berm around the power station at Fort Calhoun. The Brownsville Nuclear plant down stream in Nebraska is still dry.
However, on June 7th the Cooper station had a fire that stopped the cooling pumps for the spent fuel rods for over 90 minutes. Prior to this the plant was at level 1 emergency due to the flood. After June 7th the warning was placed at level 4, and a no fly zone over or within two miles of the plant was ordered by the FAA. Also news black outs of the on going problems at the plant was ordered. Armed guards are now patroling the area to keep news reportors away.
I was made aware of the on going drama at the plant just yesterday from a freind who is an EMT at a fire station. Checked it out on the web and sure enough there is plenty of coverage on this. You tube has tons of news footage from sources like MSNBC, RT news and others. Our local news justs states everything will be OK as long as the berm around the plant holds back the Misouri river water. NEWS FLASH, the berm failed early this morning and they are now scrambling to pump water out of the turbine rooms!
The crippled plant has had its problems in the past and is leaking radioactive tridium. Maybe all the flooding will wash the nueclear waste down stream to places along the Mississippi delta!
Try and attach a small photo of the plant taken a few weeks back before the river rose another foot or so. By the way, its been pouring rain the past several days all over the drainage area of the Misouri river from Montana to the Dakotos and Iowa, Nebraska, you name it- wide spread 2 plus inch rains. Had nearly a foot of rain here in the past week and a half over an already saturated ground. Wonder what this will due to the river levels now?
There is some real crazy news going on around the world concerning the Cooper Nueclear plant in Nebraska, and fears of a core melt down. They are comparing this to the disaster at the Fukushima plant in Japan. So far I not glowing in the dark and nothing has fallen off, but will keep you all in the loup in case anything spectacular happens around my neck of the woods.
