Coolsat 5000 motor setup?
justdave
31
Thanks so much for your help. You guys are the best. On my coolsat motor setup page, under the satellite selection there is a selection for a freq. What do I set this for. Is this information on the LyngSat web page? :)
what do you mean?
When you set up the motor, you set it up to the satellite that is the same as your longitude (give us your location and we can tell you what your true south is)
As an example, I am at 45N 93W (Mpls, MN) so my true south is IA6 (Telstar 6). I bring up T6 and select an active transponder (Lyngsat has them listed) then aim the dish :)
Ok I think I got it 79 is close to my true north. But I was not sure about selecting the transponder. Thanks
If 79 is your true south, select one of these 2 transponders
12182 freq
H polarity
23000 symbol rate
or
11742 freq
V
11110
Both are up 24/7 and will help aim the dish :)
"23000 symbol rate" Can this be changed on a coolsat ? If so where? Thanks
yes
go into the manual scan and change it...but the Coolsat should have that transponder in there properly :)
Will a Direct TV LNB work with coolsat for FTA?
Mounting a seperate ku lnb to prime focus
