Coolsat 5000, add satellite?
Indy
992
36
Indiana
Just wondering if there is a way to add IA8 @ 89.00* west to the satellite list on the Coolsat 5000. I have played with the menu and looked in the manual and do not see the procedure. Am I missing something here?
IA8 is not logged in the box. Go to dish setup, scroll to bottom and add it. There are 2 blank satellites. To get it to say the right spot (89.0W) after you save it, go to motorized, select USALS and put it in. Even if you use 1.2 (like I do), set it up for USALS, save it, then change to 1.2
It will store it as 89.0W
Thanks Iceberg!!!
I`ve had this same question for some time. If it`s in the CoolSat manual, I sure haven`t been able to find it............
Ice, thanks, your procedure worked for adding the satellite. Now I guess I have to download Channelmaster to re-do the satellite order list. IA8 is all the way at the bottom of the list which is a little quirky.
on ChannelMaster you can add more. I think to move it up and down is
click on satellite
hold down ctrl and press up or down arrow to move
Can't program Coolsat 6000 Premium
Elliptical Dishes
