Coolsat 4000pro worthed to use?
xapatista
California
Hi everyone,
I got a Coolsat 4000pro as tip after a DirecTV installation for a customer.
Is it worthy to use the Coolsat 4000pro? This is the first and only receiver i have besides 722k from dish network.
What Dish Antenna should i use to work with coolsat 4000pro? in case i do get positive feedback on the before mentioned receiver?
I have some spare 1000+ Dish Antennas... would that work for113.0°W SatMex 6 Ku? i read in Thelist that you need a 1.2 meter dish for this 116.8°W SatMex 5 C where can this dishes be found?
thanks,
xapatista
I don't have any experience with the particular unit, but it should be fine for any standard FTA channels.
The 1000+ LNBF cluster won't work as is for standard FTA but if you have an old superdish it will. Or a primestar. Do some more reading around here, you are sure to find some good information.
welcome :wave
most of the channels you linked to need C-Band. a 6 foot dish would be the best (minimum). A 1.2m dish would work with the stronger channels but you may not get all of them
I think the Coolsat 4000 is "worthy".
There are some Spanish channels available on Ku band which would require a dish bigger than the Dish 1000, but not as big as C Band requires. This list of Ku channels might be of interest to you...
FTAList.com - Spanish Channel List
However, the best (and most) Spanish programming is on C Band. 121W has some real quality Spanish channels.
lost whitesprings
Trimax SM-2500 vs Super Buddy
