Iceberg said:stephen
There are 2 version...a T55 which is like a 20" dish and the T90 which is larger.
I noticed (like most dishes above 30") that its a bugger in shipping (around 100 bucks) for one of those.
Also, can you use regular DBS LNB's on there or do you need the special "reverse" ones?
good to knowTron said:The T-90 will work fine with ordinary Ku LNBFs, it only needs the reversed ones for circular signals.
unless you are using it for a Dish subscriptionActually, I believe it would work with ordinary DBS LNBFs, but the transponders would scan in at the opposite polarity (which might not be that much of a problem anyway...)
