Parts list:
2 x 1 & 1/4" conduit hanger brackets @ 68¢ ea
2 x 3/4" spacers to take 1/4" bolt, not threaded @ 69¢
(no washers)
I turned the top (LNB) bracket around so its bolt is at the top , too.
To do so, I had to drill two holes in the bottom of the upper bracket, near its base.
Then, a supplied bolt was put through the lower bracket (the one mounted to the dish arm), then through the bottom of the upper bracket, and also through a 3/4" spacer.
By tightening the screw, the upper bracket crushes a bit, but that is acceptable.
Get the proper angle between the two brackets (I wanted 29º) and cinch that sucker tight!
To get the brackets misaligned by 29º, I needed to grind a bit off the lower bracket.
See picture with two arrows. About 1/16th inch needed to be taken off between the arrows.
Depends on how low on the upper bracket you drill the hole
My fat necked Invacom required the upper bracket be stretched open quite a bit to get the LNB in.
Then, the bolt was replaced, and snugged as required.
With the lower (pivot) bolt rock-solid-tight, you can tweak the top LNB-holding bolt all you want and never suffer for your mistakes.
You can even replace the LNB without losing alignment.
In the last picture, you can see a home-made 3/4" spacer in the end of the LNB arm, where the bracket is secured.
The spacer prevents the arm from crushing, when you snug down the bracket on it.
A commercial spacer would work as well.
I know if the actual height of the LNB horn isn't perfect , and the angle perfect, it'll throw off the elevation of the dish.
I'd tell you how much error I had, but unfortunately, I mounted the whole thing on a pole that was off-plumb by around 20º to the south.
It was all I could do to aim the dish high enough to get Whitesprings.
You may see two kinds of brackets in the pictures.
They came from different home building stores.
The one shown for the LNB is actually from Home Depot, and I recommend it over the lower one from OSH (Sears version of Home Depot).
Hopefully, by being long-winded and supplying sufficient pictures, anyone could do a similar bracket.
Thanks a bunch to z4ccamaro for his inspired bracket idea , without which this one would never have come about.
From an old thread, but good stuff!
Yesterday I built the first of these brackets - plus washers - and an extension for my D500. I used a straight edge to get the proper focal distance and angle marked on the LNB arm. I verified this by dropping a "naked" circular LNB in the mount and the 129w signal matches what I am getting from my 1K2 dish for pay tv.
Unfortunately my StarBox POS doesn't seem to work, but I will be able to use an FTA receiver next weekend. Can't wait to get my first FTA signal! I have been slowly collecting switches, brackets, etc and am ready to start in more seriously. My current plan is to use two GEOSATpro 90cm dishes (97/101 + 110, and 125/129) and attempt 103 with my modified D500. Once I start to figure out feeds, I will have to reconfigure or add on...
Attached are photos from my work yesterday. Thanks to Anole and z4ccamaro (and others) for their inspiration!
Red
PS: The quote above is from an old thread, but you can read more by clicking the link at the top.
