Once you go digital, it would be extremely hard to put any type of filter on the line.
The cable system is either a 550 Mhz, 750 MHz, or 860 MHz system. Usually everything below 54 MHz is phone, Internet, and On Demand. Analog channel 2 is at 54 MHz and every analog channel after that is 6 MHz apart up to channel 100. If there are empty analog channel numbers, those frequency bands may be used by digital channels. Only one analog channel can fit into a 6 MHz band but if it is used by digital channels, a band can supports multiple channels up to a total of 38.6 mb/s on a 256QAM system. Typically digital SD channels use between 2.5 mb/s to 3.5 mb/s so approxiamtely 10-16 digital SD channels can fit into one 6 MHz band. HD channels are anywhere from 10 mb/s to 19 mb/s so either 2 or three HD channels can fit into a 6 MHz band. Also HD and digital SD channels can be intermixed into one 6 MHz band.
Above channel 100 are the remainder of the digital channels. The STB aquires a map from the headend to map the digital channels to the displayable channel on the STB. Since there are various size cable systems and mapping can be done by the STB, there isn't any fixed channels when it comes to digital. It would be nearly impossible to have fixed channel numbers like analog due to the large number of digital channels which would probably cause conflicts if they were fixed.
If you have a Motorola 6200, 64xx, 34xx, or possibly a standard digital STB (I can't tell you how to do it though with a standard STB) you can determine where each of the digital channels lies with the cable system. Perform the following to determine the band for the channel.
Select the channel that you want to determine which band that channel resides in.
Power down the STB/DVR and hit Select/OK within 2 seconds.
A diagnostic screen will appear.
Down arrow to d06 Current Channel Status.
Click Select/OK.
The Inband Frequency for the channel will be displayed.
Use this formula to determine the band. (Inband frequency - 54)/6+2.
As an example and Inband Frequency of 717 will produce the following.
(717-54)/6+2 =
112 (the band or physical channel number).
You can possibly determine if you are on a 550 Mhz, 750 MH or 860 MHz cable system. If you not see bands or physical channels above 84 you are on a 550 MHz system. If you see channels above 117 your are on an 860 MHz system but if see bands only below 117 but also above 84 you are on a 750 MHz system.
Even if you we able to determine where your channels resided today, tomorrow they may reside in another place. This is because Comcast may reorganize the system whenever a new channel is added or removed.
